Eyal's avatar
Eyal
Aug 02, 2020
help in building irule
Hello
I would appreciate your help in building irule
I need an irue that checks if a request is coming to the address that contains the URL https://owa.domain.com/EnterpriseVault
Will refer to a virtual list named symantec in port 80
Thank you
  • Your question is not clear enough for an answer.
    Please clarify what you need.
    Also, look at Local Traffic Policies, which provide sufficient basic functionality to replace many simple irules.
