05-Jun-2020 20:57
Two monitor configured on pool http and icmp , if tcp connection down on http port, will it mark the pool member as down?
because icmp is also there which can tell the pool member is up..
12-Jun-2020 11:14
If you have the pool set up so that both health checks have to pass for a pool member to be up then what you are saying should work. If it is set to at least 1 then as long as ICMP passes the pool member would be marked up.
