EuropeanITCrow1's avatar
Apr 07, 2014
Having to upgrade from v10 to v11 manually?
Hello everybody,
I need to replace an old BIG-IP 1500 platform with a stronger and newer one, and now I’m facing a weird situation: The old one cannot be run with v11, the new one not with v10.
Sticking to the askf5 best practice articles, I couldn’t find anything for such a situation. In DevCentral I found the /usr/libexec/bigpipe daol command and gave it a try: Well, I had to delete nearly all of the HA-configuration and a lot of other stuff because of error messages. After that, it proceeded some steps further but then ran into a segmentation fault. :-(
So, is there any other way I could do a migration automatically? Converting it manually would be a life’s work…
Thank you very much for your contributions!
  • nathe's avatar
    nathe
    You can restore a v10 UCS file on v11. So, build your new bigip, base config, license and provision your modules. Then restore the ucs on the new one in tmsh using the no-license and no-platform-check switches.
    See if that helps.
