HA Failover in Azure with CFE
Mr__T
No associate/disassociate operations to update
https://clouddocs.f5.com/products/extensions/f5-cloud-failover/latest/userguide/azure.html#azure
I have followed the CFE doc to upload and test failover config via postman. I have all the tags set on the Active node's nic, but during the failover, it does not failover the floating IPs
Wed, 12 Aug 2020 18:09:45 GMT - info: [f5-cloud-failover] Performing failover - execute
Wed, 12 Aug 2020 18:09:46 GMT - info: [f5-cloud-failover] Performing Failover - discovery
Wed, 12 Aug 2020 18:09:46 GMT - info: [f5-cloud-failover] Discover Address operations using localAddresses {"0":"10.20.4.24","1":"10.20.4.186"} failoverAddresses {"0":"10.20.4.26","1":"10.20.4.184","2":"0.0.0.0/0","3":"10.20.4.40","4":"10.20.5.7","5":"10.20.5.10"} to discover
Wed, 12 Aug 2020 18:09:47 GMT - info: [f5-cloud-failover] Performing Failover - update
Wed, 12 Aug 2020 18:09:47 GMT - info: [f5-cloud-failover] No associate/disassociate operations to update.
Wed, 12 Aug 2020 18:09:47 GMT - info: [f5-cloud-failover] No route operations to run
Wed, 12 Aug 2020 18:09:47 GMT - info: [f5-cloud-failover] Failover Complete
0 REPLIES 0
