HA config sync issue in lab
Hi Friends,
I need help! I just started learning about f5 and while I was labbing HA with two virtual devices, facing challenges even thou I tried multiple times to do the reconfiguration. Kindly help me solve the issue. I have created couple of VS on bigip1 and when I try it to sync bigip1 to the group which has peer bigip2 it gives below errors.
Changes Pending
1 devices with older configuration
Recommended action: Synchronize this device to group device-group-failover-2c1fa5e3ab07
Getting below logs on bigip2
Sat Dec 22 23:01:51 IST 2018errbigip1tmm[10479]01340004HA Connection detected dissimilar peer: local npgs 1, remote npgs 1, local npus 1, remote npus 2, local pg 0, remote pg 0, local pu 0, remote pu 1. Connection will be aborted.
Thanks for your help Hemant
