GTM Traffic imbalance - four locations
jo826h
I'm seeing a considerable difference in traffic to one of my WIPs across four physical locations via GTM. There is no persistence configured and I've tried both RR and Ratio for LB method. How can I restore comparable traffic amounts to all four GTMs for this WIP (again 3 locations are comparable, one is very low)?
Thanks.
1 REPLY 1
Can you share the below,
tmsh list gtm wideip <wideip-name>
tmsh list gtm pool <pool-name> members
Mask the confidential info wherever needed. Also since you say you have various location, you're best option would be to go with topology load balancing.
Post sharing, reset the stats of gtm pool and run a show command to see the DNS resolutions answered by each pool members.
