Srini_87152's avatar
Srini_87152
Jan 09, 2018
GTM topology load balancing without Regions list reqeust
Hi all,
I have question,what will happen if request coming to GTM which is no added on Regions list. is request go like round robin instead of connecting to specific location vip?
GTM WIP configured with topology load balancing.
Thx Srini
  • Hello Srini,
    If topology is chosen as the load balancing method at the Wide IP level and no appropriate topology records are available , GTM will load balance using round robin. If topology is chosen as a load balancing method at the pool level and no appropriate topology records are available , GTM will load balance using the pool's alternate load balancing method.
  • If Topology is set as preferred LB method and no topology record matches LDNS IP, alternate LB method will be used.
