gRPC load balancing with F5 and nginx
I've a requirement of using gRPC through F5 using nginx at the server level which will convert port 80 to gRPC port (50001). Flow would be like: Client will hit F5 over port 443 which invariably will forward the request to nginx over port 80 which will convert it again over designated port of gRPC (50001). I enabled HTTP2 settings in F5 but application is not responding. Is there any specific setting which i need to do for gRPC at F5 level? nginx is already configured to forward request over port 80 to http2.
So gRPC uses HTTP/2 for server side connection. While troubleshooting further, F5 is converting HTTP/2 request to HTTP/1.1 at server side hence gRPC connection is failing. Any idea if F5 support HTTP/2 at server side?
- Leonardo_Souza
Cirrocumulus
"Important: The BIG-IP system supports HTTP/2 for client-side connections only. This means that when a client that supports HTTP/2 connects to a virtual server that has an HTTP/2 profile assigned to it, the resulting server-side traffic (such as traffic sent to pool members) is sent over HTTP/1.1."
- Pedro_HaoaRet. Employee
Update:
HTTP/2 full-proxy support was added two years ago with the release of v14.1.0.
More information:
https://support.f5.com/csp/article/K04412053
- Prakin
Cirrus
does grpc support in v141.1.0? along with http/2
officially its announced in only v16.x
- Philippe_CLOUP
Employee
In addition to what has been already posted. You also have gRPC support being added in BIG-IP, starting with v16.1.0.
See K61517014: gRPC Support on BIG-IP
and also
K08041451: Configure a BIG-IP virtual server for gRPC traffic
