Manoj_Chavali's avatar
Manoj_Chavali
Jun 12, 2020
Granular Access control policies
We are trying to use the Big IP system as a SAML service provider and PingFederate as a SAML Identity Provider.  Is it possible to create an access policy which allows/denies user to access a particular protected resource based on user atrributes or groups using F5 Big IP APM?
  • Hello,
    Yes of course, If you host your SP on F5 you can allows/denies user to access a particular SAML Attributes or LDAP attributes...
    You can also using per request policy allow user to access to a specific URI depending an LDAP/AD Attributes...
    give me exactly your need and I can help you to go ahead.
    regards
    • Manoj_Chavali's avatar
      Manoj_Chavali
      Thank you for the information. Could you please point me towards any document on how to implement the authorization based on the LDAP attributes?
      • youssef1's avatar
        youssef1
        First of would you check authorization on IDP or SP? The best practice is to check authorization  on SP side, the IDP will return attribute to SP then SP will manage authorization.
        So you confirm that your SP is hosted on F5?
        regards
