Trasmontinho's avatar
Trasmontinho
Mar 10, 2020
get LLDP Neighbor through RestAPI
Is there a way to collect lldp neighboring through API or we can collect this information only through tmsh CLI ?
If yes, could you help to retrieve this API because I haven't been to find it in iControl.
Thanks for your help.
Sam
  • Have you tried GET /mgmt/tm/net/lldp-neighbors? e.g.,
    curl -sku <user>:<pass> https://<host>/mgmt/tm/net/lldp-neighbors
        "kind": "tm:net:lldp-neighbors:lldp-neighborscollectionstats",
        "selfLink": "https://localhost/mgmt/tm/net/lldp-neighbors?ver=14.1.2"
    The example does not show any data because my environment consists of only BIG-IP VEs (LLDP is not supported on VEs).
  • Hello Satoshi,
    I'll try that. Thank you for your answer. I'll keep you posted.
    Regards,
    Sam
  • Hello Satoshi,
    This commands returns part of the informations that I try to get.
    {'chassisId': {'description': 'e8:ed:f3:e4:29:6c'}, 'localInterface': {'description': '2/2.3'}, 'portId': {'description': 'Eth7/2'}}
    the fact is that I need also the remote sysname to do so. Is there another way to retrieve this information ?
    Thanks for your answer.
    Regards,
    Sam
  • How about this one?
    curl -sku <user>:<pass> https://<host>/mgmt/tm/net/lldp-neighbors?options=all-properties
