Sort By
One Time Password (OTP) is there for a security reason. By freezing OTP, your security is just the same as a password. From the OTP vendors I know I never saw the option for a fixed OTP code.
But I understand your need for web testers to have a fixed code. Can't you create some kind of check before authenticating. For example clients from some trusted sources do not need OTP, but can use a password? The APM policy is very flexible with that kind of configurations.
Regards, Martijn.
