al_c's avatar
al_c
Mar 21, 2022
F5 VPN client doesn't work on MacOS 12
Hello,
I have a single machine (new freshly installed M1) which is unable to connect using F5 VPN web app, nor via F5 Access Appstore app.
Using the web app it simply stuck on 'connecting' and a utun device is created with an ip address, but no actuall vpn access. now I have multiple utun devices.
using the F5 Access app, the app simply doesn't launch.
I've tried to delete every F5 related file in /Library and ~/Library, and re-install it  but it didn't help.
a log file is attached.
Thank you
Al
  • al_c's avatar
    al_c
    I updated the client to 7.2.2 and it's working now, Thank you Robert.
