Technical Forum
F5 VIP with NTP Authentication
Adesh
Dear,
I need to setup a F5 OUTVIP that will use NTP pools using NTP authentication Keys. How I can use NTP authentication on a F5 outvip ?
I have lot of internal client inlcuding F5 nodes that will be using same f5 outvip to get the time synched with NTP servers . Quick help will be appreciated.
Kind Regards,
Adesh Kashyap
0 REPLIES 0
