Technical Forum
F5 VE deployment in Azure VmWare Solution
sandy16
Hi experts, I have a requirement to migrate an on-prem F5 configuration to a VE in the Azure VmWare Solution (AVS). We will be going with the BYOL deployment. What I am not sure is deploying to the AVS any different than in the regular Azure world? What kind of image am I downloading?
1 ACCEPTED SOLUTION
Hi @sandy16 ,
BIG-IP VE Deployment and Support in Azure VMware Solution. BIG-IP VE deployments of all supported versions is supported in Azure VMware Solution platform. There are no special considerations or requirements for deploying BIG-IP VE in Azure VMware Solution platform as the requirements are the same as in any ESX environment.
So you have to download the same image VE as for an ESX environment.
Hope it´s works.
1 REPLY 1
Hi @sandy16 ,
Hope it´s works.
