Technical Forum
Custom Alert Banner
F5 vCMP host and guest different versions question
sky_chen
Hello All :
vCMP are 6 guests :
If host is 14.1.2 versions ,guest 1、2、3 is 14.1.2 versions,but guest 4、5、6 is 14.1.2.3 versions。
what is the affect? or no affect?
thanks all
2 REPLIES 2
PeteWhite
F5 Employee
F5 Employee
https://support.f5.com/csp/article/K14088
host and guest can be different major versions with no issues - it is likely there will be no difference between minor versions
thanks you 😀
