BCAK_258201's avatar
BCAK_258201
Apr 08, 2016
F5 v10 - Show running config
What is the command from CLI that will display the running command in version 10? I guess things are all different with tmsh on v10 and moving forward.
I'm able to show the running config on v9, but uncertain of version 10.
Any assistance would be appreciated.
Thanks, Adam
  • tmsh commands display objects in the running configuration. What configuration objects are you trying to display, or are you trying to display all objects?
  • The tmsh equivalent of "bigpipe export" (from 9.4) is "tmsh show running-config".
    Is that what you're looking for ?
    I feel obligated to also point out that version 10 has already passed end-of-software-development SOL5903, and you should be looking to upgrade to version 11.5.x or even 12.x, if your hardware supports it SOL9476
  • For compliance monitoring, I'm trying to pull the running config so that I can evaluatue the configuration settings. Basically, just the text output. Looking for the command that will display that info.
