sudarshan_cheru's avatar
sudarshan_cheru
Oct 15, 2020
f5 pool settings for loadbalancing cisco ISE radius servers
Hi , whats the best choice to choose , service-down-action settings for the cisco ISE radius server loadbalancing.
I have only one server under the pool with current f5 setup as below. UDP default profiile, Default Source address Persistence and no snat allow at pool level.
Just want to know , how better i can tune the setup to avoid Radius High Authentication Latency.
ltm virtual ise-1645-vip {
  destination 10.20.20.20:1645
  ip-protocol udp
  mask 255.255.255.255
  persist {
    source_addr {
      default yes
  pool ise-1645-pool
  profiles {
    udp { }
  source 0.0.0.0/0
  translate-address enabled
  translate-port enabled
  vs-index 228
ltm pool ise-1645-pool {
  allow-snat no
  members {
    10.10.10.10:1645 {
      address 10.10.10.10
      priority-group 10
      session monitor-enabled
      state up
  min-active-members 1
  monitor radius-ise
  service-down-action reset
ltm monitor radius radius-ise {
  debug no
  defaults-from radius
  destination *:*
  interval 180
  password "****"
  secret "****"
  time-until-up 0
  timeout 361
  username HealthCheck
  • You may like to use fastL4 profile.
    Also, if you wanna tweak buffer size of udp profile and validate.
