Technical Forum
F5-Nagios monitoring snmp
Fabio885
Hi guys,
someone can help me for the snmp monitoring on the f5?
i want to monitor cpu usage/ram and availability from a nagios server.
someone know the correct oid/mib for f5? i cant find it. 2 weeks that i research.
Many thanks,
1 REPLY 1
Shaun_Simmons
F5 Employee
F5 Employee
Hello and Good Day to you!
  • Check out the following link. There are several plugin available to monitor the F5s on the Nagios website.
https://exchange.nagios.org/directory/Plugins/Hardware/Network-Gear/F5
Also see the following F5 Deployment Guide: https://www.f5.com/pdf/deployment-guides/nagios-ltm-dg.pdf
And a list of useful OIDs to monitor: https://somoit.net/f5-big-ip/f5-big-ip-useful-snmp-oids-monitor
Cheers!
