Technical Forum
F5 LTM health monitor to check IBM DB2 master or slave node
Bartosz_Krajews
Hello,
Using F5 LTM health monitor how to check which IBM DB2 in the pool is master and which is slave? Which monitor to use for it?
Is there a way to do it using http monitor?
Thanks a lot.
1 REPLY 1
boneyard
MVP
MVP
that depends on if there i a different response form a webpage on the master or the slave? is there perhaps such an url you can request?
