14-Jul-2023 09:21
Dear Community, I installed Journeys and it works fine, but I have a question with the UCS files that they can generate (it gives me the option to generate them for the r-series and Velos). Are these files compatible with an i-series device?
Regards!
14-Jul-2023 13:33
@Sebastian_Agui1 I have never personally performed a migration between those two platforms but it seems like the platform-migrate or no-platform-check might be the route to go. The following articles might be of use to you.
https://my.f5.com/manage/s/article/K82540512
https://my.f5.com/manage/s/article/K14906
https://my.f5.com/manage/s/article/K4423
This might end up being a trial and error thing if no one else chimes in to confirm that it will work.
19-Jul-2023 01:54
@Sebastian_Agui1 Now, Journey support only VELOS and rseries in offline mode but you can try the online mode.
Please check the below articles:
https://github.com/f5devcentral/f5-journeys/issues/77
https://github.com/f5devcentral/f5-journeys/issues/47
Thanks,
