Technical Forum
F5 iRule for persistence with header and source address persistence as fallback
eLeCtRoN
Cirrus
Cirrus
Hello,
I'm not so good in iRules, but maybe someone can give me some examples, I have an VS for more than one service with an iRule like this below
   if {[string tolower [HTTP::host]] starts_with "company.com"}{
      if {[string tolower [HTTP::uri]] starts_with "/human"}{
         pool "pool_human"
      } elseif {[string tolower [HTTP::uri]] starts_with "/body"}{
         pool "pool_body"
      } elseif {[string tolower [HTTP::uri]] starts_with "/dev"}{
         pool "pool_dev"
so now I want to integrate in this iRule a decision, for the /body should be an header persistence active, for example the request arrives with header1 it should persist to node1 in the pool_body and with header2 it should persist to node2 in the pool_body. If is header 1 and 2 not present he should use source address persistence as fallback persistence. Is that possible ? Could someone show me an example how could I the existing iRule extend with my requirement ?
thx
kind regards
6 REPLIES 6
Hi @eLeCtRoN ,
I have a bit poor environment to test my script for you , so sorry for that.
I have written this script for your case , Find it :
         pool "pool_human"
      } elseif { [string tolower [HTTP::uri]] starts_with "/body"}{
        if {[HTTP::header "xxx"] contains "header_1"}{
         pool "pool_body" member 10.10.10.10 80
      } elseif {[HTTP::header "xxx"] contains "header_2"}{
         pool "pool_body" member 10.10.10.20 80
      pool "pool_body"
      persist source_addr 255.255.255.255 3600
         pool "pool_dev"
> For "/body" conditions , I have added a new loop For pool members selections and persistence as well.
> I assume you have a header "xxx" and should contain "header_1" or "header_2" to select one of pool_members
( 10.10.10.10:80) or (10.10.10.20:80) are for examples to test the validity of my iRule script , you need to change both of them to " Pool_body" members ips and port , okay?
> this line ( persist source_addr 255.255.255.255 3600 ) to make source address affinity persistence as a fallback ip the the first and second conditions fails , Mask " 255.255.255.255 " is to make persistence by ip not subnet , you can specify subnet if you need that , Also "3600" attribute means the duration that Big-ip stores the source ip in persistence record table .
try it and give me your feedback , I will try to simulate this environment on my lab to see.
> I recommend that you perform it in a test virtual server and take Packet capure to see if iRule does its job or not.
Regards
_______________________
Regards
Mohamed Kansoh
@eLeCtRoN ,
> The First iRule I sent , it depends on you have a specific header but has two values (header_1 & header 2 )
So persistence will take effect based on this.
> But when I read you request now , I thind you meant by ( header_1 & header_2) that they are header names that coming in requests not values , So that I have modified it to this iRule script :
         pool "pool_human"
        if {[HTTP::header exists "header_1"] }{
      } elseif {[HTTP::header exists "header_2"]}{
      pool "pool_body"
         pool "pool_dev"
Try it , also I am implementing a simulated Lab to test it.
Hope it helps you.
Regards
Mohamed Kansoh
Ahmed69
The virtual server's Fallback Persistence Profile option allows the system to use only two persistence profiles: Destination Address Affinity (dest_addr) - Directs session requests to the same server based solely on the destination IP address of a packet.
Price Chopper Employee Login
Hi @Ahmed69 ,
He needs it through iRule not by virtual server resources Fallback persistence.
I have implemented it above.
you can test it if you have such this scenario.
Regards
Regards
Mohamed Kansoh
eLeCtRoN
Cirrus
Cirrus
Hi Mohamed,
thx for your example, I can test it in the end of this week. If I have an feedback for you I let you know.
kind regards
@eLeCtRoN ,
Thanks , I hope it work with you.
Regards
Mohamed Kansoh
