Technical Forum
F5 GTM Subdelegation
JBonnet
I am practicing sub delgeation exercise in the lab, in my DNS server I am delegating subdomain  wip.domain.com to the F5 devices, current zone file for domain.com:
$TTL    604800
@       IN      SOA     domain.com. admin.domain.com. (
                 57     ; Serial
                900     ; Refresh 15 mins
              86400     ; Retry
            2419200     ; Expire
             604800 )   ; Negative Cache TTL
; name servers - NS records
                        IN      NS      ns1.domain.com.
                        IN      NS      ns2.domain.com.
; name servers - A records
ns1.domain.com.         IN      A       192.168.242.200
ns2.domain.com.         IN      A       192.168.242.201
www.domain.com.       IN CNAME www.wip.domain.com.
wip.domain.com.       IN NS gtm1.wip.domain.com.
wip.domain.com.       IN NS gtm2.wip.domain.com.
gtm1.wip.domain.com.  IN      A       10.10.4.50
gtm2.wip.domain.com.  IN      A       172.16.14.50
In the F5 GTM device I created a wideip - www.wip.domain.com - this works returning the relevant A record.
Now I noticed when I created this, a zone was created in zonerunner "this.name.is.invalid"  which creates a default NS/SOA and A record (pointing to 127.0.0.1).
What is the correct process that must be done further? since any NS queries etc which are polled to the GTM respond with "this.name.is.invalid"
- should I update zonerunner with the subdomain zone records, I tried to do this from  https://support.f5.co/csp/article/K35603050 but adding a second nameserver in the zone failed  (gtm2.wip.domain.com).
- or should I create a primary/secondary nameserver on the GTM's for the subdomain?
Thank you in advance
1 REPLY 1
xuwen
MVP
MVP
The existing SOA and NS records of the zone under the zonerunner will not be overwritten by the above operations. I recommend you to delete the wideip www.wip.domain.com and then delete zone wip.domain.com under zonerunner
Finally, modify the SOA and NS record values of the zone automatically generated by wideip:
modify gtm global-settings general wideip-zone-nameserver gtm2.wip.domain.com.
After the above steps are completed, you can create a wideip www.wip.domain.com, and then observe the SOA and NS records whether change to gtm2.wip.domain.com.
and create a another wideip www.test.com, and under the ZoneRunner zone test.com.
its NS and SOA will also be gtm2.wip.domain.com.
Tips: low version in GTM, such as V12, wideip create zone default SOA and NS value is F5 hostname
