15-Apr-2019 12:32
I have two MySQL server behind F5 and i am using Priority group for active-passive so request will go to primary everytime until it's down.
Question:
How do i force my pool member to tell drop all connection and go to new primary DB? problem is if some client keep writing data to standby it will create some kind of issue.
force offline doesn't drop active connection
15-Apr-2019 19:46
There is no built-in function to delete active connections to a pool member; disabling a pool member keeps new connections from being load-balanced to a pool member, setting a pool member to forced offline will stop persistence from being honored, but to end an active connection, the general advice is to go to the connection table and delete the connection there.
You could create the functionality you are looking for (where connections to the secondary instance are reset as soon as the primary node is available) by doing the following:
When your primary node goes down, the secondary node comes up, new connections get load-balanced to the secondary node. When the primary node comes back up, the reverse logic of the monitor will force the secondary node offline, and the action on service down reject behavior should reset the client connection, forcing the client to make a new connection, which will be load-balanced to the primary node.
23-Apr-2021 04:22
hi,
I need the same system with rtmp streams but it seems it doesn't work :
any idea ?
17-Apr-2019
02:29
- last edited on
05-Jun-2023
11:19
by
JimmyPackets
Hi Satish,
you may take a look to the iRule below.
The iRule deploys a periodic
[after]
taskjob within each TCP connection, which compares every few seconds your selected pool member with the currently prefered pool member (influenced by its health, forced offline status and priority group settings) and reject the ongoing TCP connection if those are not matching anymore.
Cleaned iRule
when RULE_INIT {
set static::connection_check_interval 5000 ; msec
when LB_SELECTED {
after $static::connection_check_interval -periodic {
if { [lindex [LB::select] 3] ne [LB::server addr] } then {
reject
Debug enabled iRule
when RULE_INIT {
when LB_SELECTED {
set connection_timestamp "[TMM::cmp_group][TMM::cmp_unit][clock clicks]"
log local0.debug "Node UP Check: $connection_timestamp : The pool member [LB::server addr] is currently active. Scheduling initial status check in $static::connection_health_interval ms."
log local0.debug "Node UP Check: $connection_timestamp : Performing status check for pool member [LB::server addr]"
log local0.debug "Node UP Check: $connection_timestamp : [LB::server addr] is not the active member anymore. Rejecting the TCP connection."
reject
log local0.debug "Node UP Check: $connection_timestamp : [LB::server addr] is still the active member. Scheduling next status check in $static::connection_health_interval ms."
Cheers, Kai
29-Jan-2020 00:31
Hi, Kai.
Thank you for this iRule! May I know what exactly this line does and what significance is the number 3?
May I also ask how to tweak the iRule so that it will still work when there are multiple pool members assigned on each priority group? I have noticed that the iRule is only applicable if there is only one pool member assigned on each priority grp.
21-Feb-2020 06:18
Hi Aries22,
the [lindex 3] command parses the output of the [LB::select] as a whitespace speperated list and then selects the fourth ([lindex] starts counting on zero) element.
The output of [LB::select] has the following format and the bold part is the string we are going to extract...
pool <poolname> member <ip_addr><port>
Cheers, Kai
