F5 configuration for minio http server and chunking
Good day.
I have a S3 minio http server behind my Big-IP VE. This server uses chunking for transferring files and have problems with tranfer files in more than one chunk.
The reccomendations for Nginx configuration as a reverse proxy are https://docs.min.io/docs/setup-nginx-proxy-with-minio.html and listed below.
The main statements are "proxy_set_header Connection "" " (I suppose it may be solved by an iRule inserting the corresponding header) and "chunked_tranfer_enconding off" - what should I do?).
What should I do to match the BigIP configuration to Nginx?
Thank you.
client_max_body_size 0;
# To disable buffering
proxy_buffering off;
location / {
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Host $http_host;
proxy_connect_timeout 300;
# Default is HTTP/1, keepalive is only enabled in HTTP/1.1
proxy_http_version 1.1;
proxy_set_header Connection "";
chunked_transfer_encoding off;
