10-Mar-2021 23:06
Hi Team,
In recent vulnerability scanning done on the Infra, we found the below vulnerability on server running behind the F5 VIP.
F5 BIG-IP Cookie Remote Information Disclosure (20089)
I followed the https://support.f5.com/csp/article/K14784?sr=45997495 article to encrypt the cookies
But still the vulnerability appears on the scanning
I have 2 questions:
Solved! Go to Solution.
13-Mar-2021 02:07
Update: today morning I googled the title and id, they appear to be from Nessus (ID 20089) and they are related to how BIG-IP systems are encoding the IP address and port number in persistence cookies.
This process is described here: K6917: Overview of BIG-IP persistence cookie encoding
and the encoding can easily be reversed. This could give a malicious actor access to sensitive information regarding your internal networks.
Follow the steps described in this KB article and you should be good.
It even has a video how to do it 🙂
12-Mar-2021 12:32
Hi. No idea of the answer but I did find another article about this: https://devcentral.f5.com/s/articles/encrypting-cookies
Not sure if that'll help but hopefully it does. If not, pop back here and let us know.
ps
12-Mar-2021 13:47
Don't get me wrong, but from experience... does the VIP have a cookie persistence profile assigned?
What kind of cookie persistence method do you use with that VIP?
Can you compare the cookies when encryption is enabled / disabled?
I would try to validate with all the above checks that the vulnerability scan is not reporting a false positive.
EDIT: Also compare when cookie encryption is enabled / disabled in the http profile.
13-Mar-2021 02:07
15-Mar-2021 09:08
Thanks for the response
Could you please tell me on which capture I can see the cookies (like tcpdump)
15-Mar-2021 11:05
Yes, with tcpdump.
There is a lab guide from some random ADC training that covers all tcpdump options and tips & tricks:
Troubleshoot with tcpdump and Wireshark
There is this awesome devcentral article on how decrypt SSL:
Decrypting TLS traffic on BIG-IP
As an alternative you can simply use Firefox or Chrome browser and start Developer Tools (F12 button). You can see the cookies from there and check whether they are encrypted or not. Just compare how they look when encryption is enabled / disabled in the profile.
16-Mar-2021 03:08
Hi Daniel,
Thanks a lot for you answer.
I could able to resolve the issue through the Cookie encryption persistence profile, also able to demonstrate with the Developer Tools on Browser 🙂
