04-Dec-2020 06:00
I've been searching the portals and forums but can't find a definitive answer.
I need an ISO to install Big IP APM appliance on Hetzner Cloud, does this exist? Can somebody point me to the correct download link?
All I've been finding sounded like update ISOs, not suitable for an installation from scratch.
Best regards,
Erik
04-Dec-2020 10:09
Are you trying to install ISO image in virtual machine(KVM Linux/CentOS)? Yes.
I would recommend to install qcow2 format.
BIGIP-13.1.3.3-0.0.6.LTM_1SLOT.qcow2.zip
https://downloads.f5.com/esd/eula.sv?sw=BIG-IP&pro=big-ip_v13.x&ver=13.1.3&container=13.1.3.3_Virtual-Edition&path=&file=&B1=I+Accept
hope it will work
06-Dec-2020 04:54
sorry but I require an ISO. I don't have root access to the hypervisor. All I can do is mount an iso image to start an installation process, like with other Linux distributions.
Is there a reason you recommend version 13.1.3.3?
Thanks,
Erik
