Joel_James_Merc's avatar
Joel_James_Merc
Dec 01, 2020
F5 BIG IP and MS ADFS integration
Hi Guys,
I would like to ask if ADFS server need to enable ADFS Proxy (WAP) configuration for F5 BIG IP to replace the WAP role?
Thank you.
Regards,
Joel
  • If you are using BIGIP APM as WAP for ADFS, you won't need to enable WAP feature on ADFS servers. Basically, BIGIP APM would be used as ADFS proxy and configured for MFA/authentication of remote users.
