Technical Forum
F5 BIG-IP 4200v teardown/disk removal
pstoianov
Altocumulus
Altocumulus
Hello all,
Does anyone know how to open the chassis and remove hard drive from F5 BIG-IP 4200v as we can't find any screws?
Installation manual is not helpful as it describes how to install only but not how to decommission.
Thanks!
2 ACCEPTED SOLUTIONS
buulam
Community Manager
Community Manager
Hi @pstoianov I will see if I can dig up any info from one of the hardware folks I know. I probably won't hear back until Monday but I'll let you know what I find out.
@buulam / YouTube.com/DevCentral
buulam
Community Manager
Community Manager
Hi @pstoianov I was able to get ahold of this diagram for you that should guide you.
4 REPLIES 4
buulam
Community Manager
Community Manager
buulam
Community Manager
Community Manager
Following your schematic, I have found these micro screws which were below warranty labels.
Thank you @buulam
buulam
Community Manager
Community Manager
That is great to hear! Glad it helped!
