Technical Forum
Custom Alert Banner
F5 AS3 set ProfileHTTP=None
Aure
Hello
I'm trying to set my profileHTTP in virtual-server to None
I tried different method with a "use" or "bigip", with a none, /common/none, false
but impossible
how do I set my profileHTTP to None via AS3?
thanks you for your help
best regards
1 ACCEPTED SOLUTION
Try creating TCP service with AS3.
Non-HTTP Services (f5.com)
If you need it to have ssl certs try adding them but I have not tested this but it should work as there is client_TLS and server_TLS under the Service_TCP declaration.
Appendix A: Schema Reference (f5.com)
2 REPLIES 2
mihaic
MVP
MVP
If the VIP has 'class: service_HTTP' I don't think you can have no HTTP profile.
Try service_TCP.
