Technical Forum
F5 APM Inactivity timeout behavior
geeky-rits
With reference to APM used in conjunction with VMware Horizon View and this article:  https://support.f5.com/csp/article/K12300, I have a couple of queries :
1. How does APM detect whether or not a user is inactive ?
2. When the inactivity timeout kicks in, what does it do ? Mark the session state as locked or something ? Does it also pass some message to VMware Horizon View Connection Server ?
3. When the inactivity timeout kicks in, does APM close already launched applications/desktops ?
3a. If YES, how does it do that ? Does it have visibility into launched applications/desktop OR does it talk to VMware Horizon View Connection Server to get that done ?
3b. If NO, how does it keep existing applications as is, esp. if VMware Horizon View Connection Server closes them, when inactivity timeout kicks in ?
Thanks in advance !
1 REPLY 1
CA_Valli
MVP
MVP
1. APM injects a session cookie in client traffic. No request with session cookie = client is inactive.
2. Session expires and APM removes it from session table. Clients requires another authentication. Not sure how this interacts with VMware.
3. Also nont sure, I think this might as well depend on VMware settings. I think it will be the same behavior as an user who authenticates another time.
Hope this helps
CA
