F5-apm Device Certificate Expires issue
sky_chen
Hello All :
If apm Device Certificate date Expires old , what is the affect? or no affect?
As far as I know, only ltm and gtm have an affect.
thanks all
2 REPLIES 2
Yoann_Le_Corvi1
Cumulonimbus
Cumulonimbus
Hi
I don't believe you will have any effect appart from a big warning in your browser if we are talking about the Device Certificate and not the "Device Trust" certificates.
But why would you want to let it expire ? 🙂
Check this for detailed info :
https://support.f5.com/csp/article/K15664
Yoann
sky_chen
ok , thank you 。😅
