Technical Forum
f5 and cisco ACI integration issue
abiselom
when I try to integrate f5 with ACI I got some issue and i attach the issue on the below screen shoots
can anyone helps me out?
thank you!
1 REPLY 1
CA_Valli
MVP
MVP
It's pretty self-explainatory. You must edit your pool "web_pool" so that it only contains static members (objects configured with a static server address, ex. 10.10.10.10) or that it only contains dynamic members (objects configured with a FQDN and resolved with DNS query, ex. server1.localdomain ), but not both.
