Technical Forum
F5 Active Standby Node Configuration
starboy
Cirrus
Cirrus
Hi All
I am writing to inquire about the configuration possibilities of the F5 Load Balancer in relation to my active standby webservers.
Currently, I have a setup where my active standby webservers are accessible to the public. However, I would like to explore whether it is possible to configure the F5 Load Balancer in such a way that it can forward traffic to the active server and automatically failover to the standby server when the active server is down.
1 ACCEPTED SOLUTION
Hi @starboy ,
you can do this by Priority gropt Activation , it's a more efficient way to do high availability on servers/pool members level.
you will find all details over this article :
https://my.f5.com/manage/s/article/K13525153
_______________________
Regards
Mohamed Kansoh
2 REPLIES 2
Hi @starboy
With the help of Priority Group Activation option, you should be able to achieve it.
Refer this article for the details.
Hope it helps!
Hi @starboy ,
Regards
Mohamed Kansoh
