Technical Forum
Custom Alert Banner
External MOnitor for LTM using CURL
Deepak_Nair
Cirrus
Cirrus
Hi ,
i am setting UP an external Monitor using CURL for application monitoring for select number of backend servers . This is the script i am using as per F5 DOC
https://support.f5.com/csp/article/K31435017
I am seeing below error while running my Monitor check with backend server :
[0][13575] 2021-03-05 19:09:50.903983: ID 221 :(_add_service_list): [ addr=::ffff:10.149.22.25:5550 srcaddr=none mon=/Common/SOLACE_5550 up_intvl=5 dn_intvl=5 timeout=16 time_until_up=0 immed=0 next_ping=[1614942199.877925][2021-03-05 19:03:19] last_ping=[0.000000][1970-01-01 08:00:00] deadline=[1614942220.877925][2021-03-05 19:03:40] on_service_list=True ]
[0][13575] 2021-03-05 19:09:50.904855: ID 221 :(monitor_and_params): /Common/SOLACE_5550: ARGS_I= , URI= /health-check/guaranteed-active, RECV= 200 OK, RUN_I= /Common/Curl_Monitor_EX, [ addr=::ffff:10.149.22.25:5550 srcaddr=none mon=/Common/SOLACE_5550 ]
[0][13575] 2021-03-05 19:09:50.904908: ID 221 :Probing monitor instance '/Common/SOLACE_5550' '/Common/monitor_test' 5550 [ addr=::ffff:10.149.22.25:5550 srcaddr=none ]
[0][13575] 2021-03-05 19:09:50.905000: ID 221 :(main_loop [next_ping]) Closing logging file /var/log/monitors/Common_SOLACE_5550-Common_monitor_test-5550.log
[0][13575] 2021-03-05 19:09:50.905084: ID 221 :(_do_ping): time to ping, now=[1614942204.880927][2021-03-05 19:03:24], status=UNKNOWN [ addr=::ffff:10.149.22.25:5550 mon=/Common/SOLACE_5550 fd=-1 pend=0 #conn=0 up_intvl=5 dn_intvl=5 timeout=16 time_until_up=0 immed=0 next_ping=[1614942199.877925][2021-03-05 19:03:19] last_ping=[0.000000][1970-01-01 08:00:00] deadline=[1614942220.877925][2021-03-05 19:03:40] on_service_list=True snd_cnt=0 rcv_cnt=0 ]
[0][13575] 2021-03-05 19:09:50.905145: ID 221 :(_spawn_external_pinger): /config/filestore/files_d/Common_d/external_monitor_d/:Common:Curl_Monitor_EX_61726_1 [ addr=::ffff:10.149.22.25:5550 ]
[0][13575] 2021-03-05 19:09:50.905819: ID 221 :(_spawn_external_pinger): spawned EAV pid=9276 [ addr=::ffff:10.149.22.25:5550 fd=20 ]
[0][13575] 2021-03-05 19:09:50.905924: ID 221 :(_do_ping): post ping, status=UNKNOWN [ addr=::ffff:10.149.22.25:5550 mon=/Common/SOLACE_5550 fd=20 pend=0 #conn=0 up_intvl=5 dn_intvl=5 timeout=16 time_until_up=0 immed=0 next_ping=[1614942209.877925][2021-03-05 19:03:29] last_ping=[1614942204.880927][2021-03-05 19:03:24] deadline=[1614942220.877925][2021-03-05 19:03:40] on_service_list=True snd_cnt=1 rcv_cnt=0 ]
[0][13575] 2021-03-05 19:09:50.954396: ID 221 :(_main_loop): Service ready for read, now=[1614942204.929748][2021-03-05 19:03:24] [ addr=::ffff:10.149.22.25:5550 srcaddr=::%0:0 fd=20 pend=0 #conn=0 ]
[0][13575] 2021-03-05 19:09:50.954422: ID 221 :(_recv_external_node_ping): reading [ addr=::ffff:10.149.22.25:5550 ]
[0][13575] 2021-03-05 19:09:50.954434: ID 221 :(recv_external_node_ping): EAV failed [ addr=::ffff:10.149.22.25:5550 ]
I am not sure what is broken . i can ping the server and telnet to the server .
i can CURL backend SRV successfully
curl -vk http://10.149.22.25:5550/health-check/guaranteed-active
*  Trying 10.149.22.25...
* Connected to 10.149.22.25 (10.149.22.25) port 5550 (#0)
> GET /health-check/guaranteed-active HTTP/1.1
> Host: 10.149.22.25:5550
> User-Agent: curl/7.47.1
> Accept: */*
< HTTP/1.1 200 OK
< Server: Solace_PubSub+_Enterprise/9.5.0.25
< Cache-Control: no-cache
< Content-Length: 0
* Connection #0 to host 10.149.22.25 left intact
1 REPLY 1
Simon_Blakely
F5 Employee
F5 Employee
Make sure that the uploaded monitor script has linux style Linefeed line endings, and not Windows style Carriage-return/Linefeed line endings.
These will break script execution.
Get a text editor like Notepad++, and use View -> Show Symbols -> Show End of Line option
