小白's avatar
小白
Icon for Cirrus rankCirrus
Feb 23, 2022
Execution order of policy
Hi,I know that for a program, there must be a sequence of execution, so what is the sequence of ASM policy?I want to know the order of various protection strategies in a policy. For example, compared with SQL injection and XPath injection, who takes effect first, and what is the order of other protection strategies?
  • Hi, Is there a particular function you would like to know this for? It may help get you to the answer.
    Do keep in mind though that the WAF system works on an "all-match" strategy (all components that are active and get matched will be reported), rather than a "first-match" strategy (like a firewall policy).
    • 小白's avatar
      小白
      Obviously, when the blacklist and injection exist at the same time, the blacklist must take effect first, isn't it? Then I believe there is a sequence for the same strategy
