Exchange (OWA) ASM Template and Cookie Violation
cd_312641
Hello,
I have a Portal Access VS which allow to access multiple applications (URIs). One of those is an OWA Exchange 2010. All is working fine.
I am now trying to secure the OWA application with the ASM module. I crated an ASM policy using the latest exchange ASM template (https://devcentral.f5.com/d/new-asm-templates). I then applied a LTM policy to my Portal Access VS, which says that if the URI contains */owa, then it must applies the ASM policy I created. All is working fine.
Now what I don't understand with that given ASM template, is that I trigger a Modified Domain Cookie Violation for the following cookies:
- tzid
- UserContext
Reason says "New". Both those cookies are set in the Enforced Cookie section of the ASM policy. I did not put them here, it is the template that did so. Why am I triggering this violation ? Is the template wrong and should have put those cookies in the Allowed cookie section ?
3 REPLIES 3
Leonardo_Souza
Cirrocumulus
Cirrocumulus
The template probably comes with a list of predefined cookies, and those 2 new cookies were not present.
Just add enforce/allow them.
If you want to double check, access the site directly and see if those cookies are sent by the server.
Add a comment in the template post, so the owner can update the template.
cd
Cirrus
Cirrus
The two cookies I mentioned are present in the template. My understanding is that Allowed cookies are cookies authorized and that can be modified by user. Enforced cookies are cookies authorized but that shouldn't be modified by user.
Both UserContext and tzid cookies are in the Enforced section, and flagged as changed by user which triggers the violation.
Both cookies are indeed sent by server.
Leonardo_Souza
Cirrocumulus
Cirrocumulus
Have a look at this solution:
https://support.f5.com/csp/article/K5907
