Technical Forum
Error while configuration discovery of F5 LTM Device On BIG IQ
sjerbi
Hi Team,
I am facing issue while configuration discovery of Bigip LTM device on BIG IQ. I am getting the following error:
Error querying 'Virtual Server' from path '/mgmt/tm/ltm/virtual' on device <DeviceName> (xx.xx.xx.xx), network communication failed due to protocol error
I am Using Virtual Edition of BIG-IQ and am trying to add BIGIP LTM Virtual Edition box of BIG-IP 14.0.0
Thanks in advance
4 REPLIES 4
whisperer
Cumulonimbus
Cumulonimbus
Sounds like an issue with iQuery or something. Maybe incompatible versions.
In either case, I would go through all of the troubleshooting steps:
https://my.f5.com/manage/s/article/K16307
If you still have issues, I would open a support ticket with F5 Support. One can usually find an interesting bug with BIGIQ when it comes to certain corner cases. On that note, make sure you have the latest version! 🙂
sjerbi
Thank you for reply, I'm allready with the last version 8.2.0.1
I will open a case ^^
Hello,
You can check the below article. Also, ensure that the self IP of the BIG-IP is having port lockdown configuration correctly.
https://my.f5.com/manage/s/article/K11078038
Thanks,
Paulius
MVP
MVP
@sjerbi I would verify that you have the appropriate ports open in the below article.
https://my.f5.com/manage/s/article/K15612
