Technical Forum
Error Running Ansible tasks on the active BIG-IP K10531487
KernelPanic
I'm getting an error running code from K10531487: Running Ansible tasks on the active BIG-IP in a device group.
This appears to be an auth error on the active device, however the play runs cleanly getting facts on the device, and this environment runs other ansible scripts on the same F5's as well. Any ideas for next steps? I appreciate your help.
Error:
TASK [Display bigip facts f5bm.express-scripts.com] ******************************************
ok: [f5bm.express-scripts.com] => {}
MSG:
[u'Hostname: f5bm.express-scripts.com', u'Status: HA_STATE_ACTIVE']
TASK [Create pool] ************************************************************************************
fatal: [f5bm.express-scripts.com -> localhost]: FAILED! => {
    "changed": false
MSG:
Unable to connect to f5bm.express-scripts.com on port 443. The reported error was "Unexpected **kwargs: {'verify': False}".
        to retry, use: --limit @/home/eh7305/scripts/ansible/f5tst.retry
PLAY RECAP ********************************************************************************************
f5am.express-scripts.com : ok=2    changed=0    unreachable=0    failed=0
f5bm.express-scripts.com : ok=2    changed=0    unreachable=0    failed=1
Playbook:
- name: "Syncing F5 Active config to group"
  hosts: "drhaf5"
  serial: 1
  vars_files:
    - "vars/main.yml"
    - "vars/vault.yml"
  gather_facts: "no"
  roles:
    - "f5syncactive"
  tasks:
    - name: "Get bigip facts"
      bigip_facts:
        server: "{{inventory_hostname}}"
        user: "admin"
        password: "{{adminpass}}"
        include:
          - "device"
          - "system_info"
        validate_certs: False
      check_mode: no
      delegate_to: "localhost"
    - name: "Display bigip facts {{inventory_hostname}}"
      debug:
        msg:
          - "Hostname: {{ system_info.system_information.host_name }}"
          - "Status: {{ device['/Common/' + system_info.system_information.host_name].failover_state }}"
    - name: "Create pool"
      bigip_pool:
        user: "admin"
        lb_method: "round-robin"
        monitors: http
      notify:
        - "Save the running configuration to disk"
        - "Sync configuration from device to group"
      when: device['/Common/' + system_info.system_information.host_name].failover_state == "HA_STATE_ACTIVE"
  handlers:
    - name: "Save the running {{inventory_hostname}} configuration to disk"
      bigip_config:
        save: "yes"
        user: "admin"
      delegate_to: localhost
    - name: "Handler Sync configuration from {{inventory_hostname}} to group"
      bigip_configsync_action:
        device_group: "sync-failover-group"
        sync_device_to_group: "yes"
        user: "admin"
6 REPLIES 6
DennisJann
You didn't mention the versions of Ansible and BIG-IP OS used in your environment. That information would be helpful for someone to reproduce and diagnose the issue you reported.
For example, using Ansible 2.4 and BIG-IP version 12.1.3, I get the following error about a missing monitor_type parameter during the pool creation task:
fatal: [bigip.localdomain -> localhost]: FAILED! => {"changed": false, "msg": "The 'monitor_type' parameter cannot be empty when 'monitors' parameter is specified."}
Once I added the monitor_type parameter, the pool creation task ran successfully.
Try checking the bigip_pool.py module in your Ansible distribution for parameter requirements.
Andy_McGrath
Cumulonimbus
Cumulonimbus
From the error and looking at the documentation my guess is the validate_certs valid is not valid. Although it is a boolean parameter the documentations does stat the value should be yes (default if omitted) or no.
Guessing the bigip_pool module is stricter on this value than other modules which may be happy to accept True or False values.
On a side note I would look to use a provider which can be set as a variable and simply referenced within each F5 BIG-IP module in a single line. As an example see the following playbook 'AnsibleF5Archiver playbook f5Archiver.yml'
KernelPanic
Excellent point sir! TMOS 12.1.3.6 ansible 2.7.5 python version = 2.7.5 GCC 4.8.5 20150623 Red Hat 4.8.5-36
I added a monitor type and have the same error. I think it has something to do with the handler but could be wrong.
Using module_utils file /usr/lib/python2.7/site-packages/ansible/module_utils/network/common/__init__.py
Using module_utils file /usr/lib/python2.7/site-packages/ansible/module_utils/network/common/utils.py
Using module file /usr/lib/python2.7/site-packages/ansible/modules/network/f5/bigip_pool.py
 PUT /home/eh7305/.ansible/tmp/ansible-local-6428wf53d0/tmpYBaaD6 TO /home/eh7305/.ansible/tmp/ansible-tmp-1548950000.6-199856288208530/AnsiballZ_bigip_pool.py
 EXEC /bin/sh -c 'chmod u+x /home/eh7305/.ansible/tmp/ansible-tmp-1548950000.6-199856288208530/ /home/eh7305/.ansible/tmp/ansible-tmp-1548950000.6-199856288208530/AnsiballZ_bigip_pool.py && sleep 0'
 EXEC /bin/sh -c '/usr/bin/python2 /home/eh7305/.ansible/tmp/ansible-tmp-1548950000.6-199856288208530/AnsiballZ_bigip_pool.py && sleep 0'
 EXEC /bin/sh -c 'rm -f -r /home/eh7305/.ansible/tmp/ansible-tmp-1548950000.6-199856288208530/ > /dev/null 2>&1 && sleep 0'
The full traceback is:
WARNING: The below traceback may *not* be related to the actual failure.
  File "/tmp/ansible_bigip_pool_payload_etue6Y/__main__.py", line 947, in main
    results = mm.exec_module()
  File "/tmp/ansible_bigip_pool_payload_etue6Y/__main__.py", line 709, in exec_module
    changed = self.present()
  File "/tmp/ansible_bigip_pool_payload_etue6Y/__main__.py", line 757, in present
    if self.exists():
  File "/tmp/ansible_bigip_pool_payload_etue6Y/__main__.py", line 836, in exists
    return self.client.api.tm.ltm.pools.pool.exists(
  File "/tmp/ansible_bigip_pool_payload_etue6Y/ansible_bigip_pool_payload.zip/ansible/module_utils/network/f5/bigip.py", line 61, in api
    raise F5ModuleError(error)
fatal: [haf5b.express-scripts.com -> localhost]: FAILED! => {
    "changed": false,
    "invocation": {
        "module_args": {
            "auth_provider": null,
            "description": null,
            "lb_method": "round-robin",
            "metadata": null,
            "monitor_type": "single",
            "monitors": [
                "http"
            "name": "pool1",
            "partition": "Common",
            "password": "VALUE_SPECIFIED_IN_NO_LOG_PARAMETER",
            "priority_group_activation": null,
            "provider": {
                "server": "f5bm.express-scripts.com",
                "server_port": null,
                "ssh_keyfile": null,
                "timeout": null,
                "transport": "rest",
                "user": "admin",
                "validate_certs": false
            "quorum": null,
            "reselect_tries": null,
            "service_down_action": null,
            "slow_ramp_time": null,
            "state": "present",
            "transport": null,
            "user": "admin",
MSG:
`    to retry, use: --limit @/home/eh7305/scripts/ansible/f5tst.retry
PLAY RECAP *************************************************************************************************************************************************** f5am.express-scripts.com : ok=2 changed=0 unreachable=0 failed=0 f5bm.express-scripts.com : ok=2 changed=0 unreachable=0 failed=1
Andy_McGrath
Cumulonimbus
Cumulonimbus
Give the following, or something similar a try. This uses a provider variable for connection details.
I remember I had an issue with one BIGIP module that didn't work correctly with the provider so is you get an error with one might need to change it back but found got less issues with the BIGIP modules that work with the provider.
Also another question question is what verion of the F5 Python SDK are you running?
- name: "Syncing F5 Active config to group" hosts: "drhaf5" serial: 1 vars_files: - "vars/main.yml" - "vars/vault.yml" vars: f5Provider: server: "{{ inventory_hostname }}" server_port: 443 user: admin password: "{{adminpass}}" validate_certs: no transport: rest gather_facts: "no" roles: - "f5syncactive" tasks: - name: "Get bigip facts" bigip_facts: provider: "{{f5Provider}}" include: - "device" - "system_info" check_mode: no delegate_to: "localhost" - name: "Display bigip facts {{inventory_hostname}}" debug: msg: - "Hostname: {{ system_info.system_information.host_name }}" - "Status: {{ device['/Common/' + system_info.system_information.host_name].failover_state }}" - name: "Create pool" bigip_pool: provider: "{{f5Provider}}" lb_method: "round-robin" monitors: http name: "pool1" notify: - "Save the running configuration to disk" - "Sync configuration from device to group" delegate_to: "localhost" when: device['/Common/' + system_info.system_information.host_name].failover_state == "HA_STATE_ACTIVE" handlers: - name: "Save the running {{inventory_hostname}} configuration to disk" bigip_config: save: "yes" provider: "{{f5Provider}}" delegate_to: localhost - name: "Handler Sync configuration from {{inventory_hostname}} to group" bigip_configsync_action: device_group: "sync-failover-group" sync_device_to_group: "yes" provider: "{{f5Provider}}" delegate_to: localhost
KernelPanic
I found through testing that this was a software issue on the ansible host, causing instability in the various modules in the script. I moved to another server and virtual environment and the script worked flawlessly. Lesson learned, always build ansible F5 in a virtualenv!
Rebecca_Moloney
Community Manager
Community Manager
For OP or anyone else coming across this post, @Matt_Mabis has a popular article F5 Automation with Ansible Tips and Tricks if you'd like to learn more.
