10-Jan-2023 03:54
Hi Everyone
Jus want to ask about enabling and disabling application security on all virtual servers on why:
10-Jan-2023 06:14
@angerica ,
Please clarify more , What is PC02 , also why do you want to disable/enable it for all services ??
10-Jan-2023 09:15 - edited 10-Jan-2023 09:16
You can dissable ASM on failure as mentioned in https://support.f5.com/csp/article/K15093
Outside of that just and an irule to each VS that dissables ASM if a variable is set to true or "1" or what you want, so that you can switch off and on. Why you would want this as @Mohamed_Ahmed_Kansoh I can't say and this is big security no no but you decide that 🙂
https://clouddocs.f5.com/api/irules/ASM__disable.html
