20-Oct-2023 09:04 - edited 20-Oct-2023 09:06
Issue:
DoS attacks are not showing on the DoS dashboard.
Information:
Any thoughts on how to fix would be much appreciated?
Thanks!
23-Oct-2023 04:01
Hi @Nolan_Jensen,
I recommend you open a support case, I have other issues with dashboards in the F5 for the WAF module, and all of these problems are related to bugs, probably support can recommend you a version to fix this issue.
Hope it works.
23-Oct-2023 08:06
Will do. Thank you for the response!
