Yathish's avatar
Yathish
Jul 27, 2021
Disable node using Python
looking out for help to disable the node in the F5 Pool.
  • Hello Yathish.
    From the pool member, you need to modify the option "session" from:
    "monitore-enabled" --> "user-disabled"
    poolmember.session = "user-disabled"
    And then, update those changes.
    poolmember.update()
    Regards,
    Dario.
