tuannguyen1712
Altocumulus
Feb 11, 2020Disable HTTP Options Method on Management Interface F5
Dear all,
Our customer just ran a pentest on F5 Mgmt IP and found vulnerability HTTP Options Method enable. I only know how to disable this on VIP IP using HTTP profile/irule but couldnt find a way to disable this on Mgmt interface. Could anyone let me know how can I accomplish this. Many thanks!
- tuannguyen1712
Altocumulus
I'm looking for the solution!!!
You can restrict management ip address(SSH n HTTPS) rather then disabling options method.
