Sort By
- youssef1Cumulonimbus
Hi Nilesh,
you have 2 choices:
generate a new cert/key which involves generating a new key (And provide your CSR to your CA).
Or just renew you certificat which involves keeping your private key (And provide your CSR to your CA).
In both case you can Modify/Add attribute (Common Name, SAN, ...).
But if you want to renewal your cert you need to generate a CSR à Unless if you delegate the creation of your certificate (private and public key) to your CA what I do not advise you.
regards
- Kevin_StewartEmployee
That generally depends on whether or not you want to keep the attributes of the current certificate (subject, issuer, ciphers, etc.). If you do, then it's easiest to simply renew the current certificate.
