28-Mar-2023 07:44 - edited 28-Mar-2023 07:46
I came accross a situation where the VIP and Pool, etc. were created by an iApp. Strict Updates was disabled and the Pool and VIP was removed outside of the iApp.
The iApp is not in use, but I'd like to cleanup. I was concerned about deleting to iApp since many of the objects under it have already been deleted. Is there any consequence to deleting the iApp via the GUI? I don't want to corrupt the config, or at least I'd like to have an idea of any fallout before I pursue it.
BigIP version 13.1.3.4 - Thanks for any insights.
Mike
Solved! Go to Solution.
28-Mar-2023 11:15
You should be just fine to delete the iApp. If you deleted elements of it, you must have had strict turned off, so go ahead and kill it.
Also.. PLEASE get an upgrade window and get that baby an upgraded TMOS! 🙂
28-Mar-2023 11:15
28-Mar-2023 11:19
Upgrade? I would but it's EoS. I'm working on mitrating to DCS and a smaller LTM-VE. Between the two I think I have it covered!
Thanks for your reply, I appreciate it.
Cheers,
Mike
