Technical Forum
Delete a traffic-group
DavidPP
I've a F5 infrastrucute with some devices in the same device group, that are divided 3 traffic-groups. I deleted all LTM configuration of the partition asigned to this traffic-group and shutdown one of the F5.
Now, I've to delete the related traffic-group, and remove this device from the device-group. There are a correct way to do this whitout affect the production platform?
https://i.ibb.co/SV7ynTh/Device-Group.png
https://i.ibb.co/8ghx2mM/Traffic-Groups.png
Thanks.
2 REPLIES 2
Aayush_Narayan
You can refer this article from f5 for removing the device form the device group.
https://support.f5.com/csp/article/K95585957#:~:text=on%20your%20system.-,Log%20in%20to%20the%20Configuration%20utility%20of%20the%20device%20you,and%20move%20it%20to%20Available.
DavidPP
Thanks a lot, for your quickly answer Aayush, but muy question is about the previous step, delete the traffic-group, as I indicated in the added images.
I supose that this step, is less aggresive than make modifications in the device-group and sync policies.
I read the link that you tell me, before write the post. Because I didn't found information about the procedures or impact when modify or remove the traffic-groups. That's my question.
Thanks again.
