Alan_Stevens_93
Dec 04, 2008Nimbostratus
Default Document not displaying in IIS
Hi all,
new to the big IP admin side of things so bear with me.
We have 2 IIS6 nodes serving up static content behind a big IP virtual. There are no iRules or profiles in place for this load balanced setup. The pool is using gateway_icmp for a health monitor. The send string is GET / no return strung.
here is what my problem is:
a user can go to http://www.sitename.com and is served the default document. A user can go to http://www.sitename.com/support/ and is served the default document. However, if a user tries to go to http://www.sitename/support - without the trailing /, the session times out on 404. If I go local to the server, I can have the page delivered with either method.
Is there a configuration change that can be made to allow the Big IP to pass the request correctly? Or perhaps an iRule?
Thanks for the help.
