13-Feb-2020 01:25
Hello.
On the BIG-IP4600 (ver 13.1.1.4) that I have set, the following errors appear in large numbers in / var / log / ltm.
/ var / log / ltm logs similar to below error message:
Wed Feb 12 09:43:33 JST 2020 err "BIG-IP's hostname" tcl_monitor PID: 7022 (_check_memory_above_limit): worker exceeded memory buffer limit 10 initial memory size 27.843750 current memory size 37.871094
There is a mail server under BIG-IP and uses "pop_healthcheck" as a health check.
This "pop_healthcheck" is created using the Configuration utility as follows.
ltm monitor pop3 "pop_healthcheck" {
debug no
defaults-from pop3
destination *:*
interval 5
password ***
time-until-up 0
timeout 16
username ***
In the F5 literature, this seems to be a known issue, but no action is required.
→ https: //support.f5.com/csp/article/K82632320
However, my / var / log / ltm is filled with the same log.
For example, can you increase the initial memory size or prevent this log from being displayed?
help me.
19-Feb-2020 01:54
Like what the article K82632320 suggested, the IMAP monitor worker restarts and the system logs a message. You might want to open a support case with F5 Support to see if this same behavior applies to POP3 or if its something else.
23-Feb-2020 13:58
Thank you for your advice.
I addressed this issue as follows:
Monitor method: pop3 → tcp (port 110)
It seems that the default pop3 monitor gets the mail list of the specified account.
The list may be too many for my environment.
