08-Nov-2018
03:57
- last edited on
21-Nov-2022
21:41
by
JimmyPackets
Hello.
I would like to use VIP-Targeting-VIP after loadbalacing decision in conjuntion with Single Node Persistence (https://devcentral.f5.com/codeshare?sid=690).
To do so, I'm using this code.
when LB_SELECTED {
Create persist-record to use it for future loadbalancing decisions
persist add uie [virtual name]
Perform VIP-Targeting-VIP base on the previous LB selection
switch [LB::server port] {
"1001" {
LB::reselect virtual VS-Test_1001
"1002" {
LB::reselect virtual VS-Test_1002
After execution, two persist entries are created
tmsh show ltm persist persist-records | grep universal
universal /Common/VS-Test_1000 10.130.40.180:1000 10.130.40.180:1002 (tmm: 2)
universal /Common/VS-Test_1000 10.130.40.180:1000 10.130.40.180:1002 (tmm: 1)
But an error occurs
$ curl http://10.130.40.180:1000
curl: (56) Recv failure: Connection reset by peer
Checking LTM log file I see this message.
Nov 8 13:32:18 F5-BigIP err tmm[13383]: 01220001:3: TCL error: /Common/Rule_VS-2-VS - Prerequisite operation not in progress (line 2) (line 2) invoked from within "persist add uie [virtual name]"
Do you know what the reason could be? Thanks.
KR, Dario.
08-Nov-2018 04:07
Forget this question. The solution is here -> https://support.f5.com/csp/article/K14411
KR, Dario.
