CPU utilization spike every night
Hello,
Which proces is running every night on 22:40 ? I can see CPU spike every night:
Is this process scheduled by cron/anacron ?
Thank you
- tatmotiv
You can check your daily jobs by looking at "crontab -l" and the contents of /etc/cron.daily. The CPU peak could also be caused by traffic processing. Do you also see spikes in SSL TPS, connection count or traffic throughput at that time?
- Vijay_E
Cirrus
I would recommend that you check the number of connections/HTTP Requests/Throughput around the time of the CPU spike. The graphs for any or all of these variables may show similar pattern. I have usually seen such increase in CPU because of automated backup of database or any other similar application level backup and because the F5 handles these connections via VS, you can see a bump in cpu utilization.
- MaCrek_56686
Altocumulus
cron.daily is configured by /etc/anacrontab:
[root@f5-1:Active:In Sync] config cat /etc/anacrontab /etc/anacrontab: configuration file for anacron See anacron(8) and anacrontab(5) for details. SHELL=/bin/sh PATH=/sbin:/bin:/usr/sbin:/usr/bin MAILTO=root the maximal random delay added to the base delay of the jobs RANDOM_DELAY=45 the jobs will be started during the following hours only START_HOURS_RANGE=3-22 period in days delay in minutes job-identifier command 1 5 cron.daily nice run-parts /etc/cron.daily 7 25 cron.weekly nice run-parts /etc/cron.weekly @monthly 45 cron.monthly nice run-parts /etc/cron.monthlyThere are interesting options like "START_HOURS_RANGE" or "RANDOM_DELAY". But my cron is not customized, so I suppose, that this is general behavior. Maybe someone else have noticed same behavior.
- tatmotiv
That's what I was looking for, too, but for some reason I cannot find /etc/anacrontab on my systems (vcmp guests running 11.6.0 HF6)... [root@mylb:/S1-green-P:Active:In Sync] config cat /etc/anacrontab cat: /etc/anacrontab: No such file or directory What version / systems are you running? - MaCrek_56686
Altocumulus
Output in my previous post is from 12.0.0 HF1. But you are right, on the other box: 11.6.0 HF5, is no /etc/anacron file. - tatmotiv
Interesting. The 12.0 release notes list only one changed behaviour that contains cron: "482950 Phone Home scheduled jobs are now scheduled based on installed time, rather than at default daily/monthly intervals found in cron.daily and cron.monthly."
