Technical Forum
Conversion license
unavailable
Cirrus
Cirrus
Hello everyone,
my customer has bought an old device where there is not license, doing a check by serial number on  F5 portal,
I have received this ionformation:
Usage                 : Production
Product Order Status  : Sales
I need to know if it is possible to generate a new license ( buying it )  to apply to this device and if it is possible  convert a license from GTM to LTM.
Many thanks in advances for everyone for your time and consideration.
Regards,
1 ACCEPTED SOLUTION
Samir
MVP
MVP
Connect with f5 support, they will guide the process.
2 REPLIES 2
Samir
MVP
MVP
unavailable
Cirrus
Cirrus
many thanks for your reply.
Regards,
